Scaling position
Hi everyone,
I use an encoder to measure linear position. The actual displacement is from 0 to 150mm, corresponding to an output from 3.51 to 14.61 of the encoder. I want to scale and map the output of the encoder to displace the actual position. How can i do this in labview?
Thanks in advance
(879 Views)
Hi Son,
How would you do that in another programming language?
You have an input range of 3.51...14.61 and you want to scale to 0...150: this is a simple linear equation with parameters offset and gain.
You should have learned the equation in school! (y = gain * x + offset)...
Determine gain/offset, then you just need a multiply&add node in LabVIEW!
(850 Views)
... corresponding to an output from 3.51 to 14.61 of the encoder.
While Gerd is of course correct, I don't quite understand your question, because an "encoder" typically provides digital counts, i.e. integers as raw data. Fractional values as you list here apparently already have some scaling applied. Can you clarify where these values come from?
(795 Views)
