02-28-2007 08:23 AM
02-28-2007 09:12 AM
02-28-2007 10:12 AM - edited 02-28-2007 10:12 AM
Message Edited by zou on 02-28-2007 10:13 AM
02-28-2007 11:14 AM - edited 02-28-2007 11:14 AM
As you can see (3) is a compromise for performance reasons. A good reason! 🙂
Message Edited by altenbach on 02-28-2007 09:14 AM
02-28-2007 11:40 AM
All -- thanks for running the tests! I'll be upgrading to 8.2 and, it seems like my needs will be met by the native scaling algorithm. Regarding additional algorithms that trade speed for results, my 2cents is that if Labview wants to get serious about image processing, then, additional algorithms should be available to the user as options. Labview is perfectly suited for this through the property node. Some applications will require speed, others will require performance -- let the user decide.
The resize function in irfanview (the freeware image processing program I use) allows the user to select if they want a resize or a resample, and for the resample option: it has 6 available resampling filters available. (see enclosed photo).
Thanks again to everyone!
-Ted
02-28-2007 11:45 AM
02-28-2007 05:04 PM
02-28-2007 05:16 PM
02-28-2007 05:47 PM
However, if I save the vi with the munched image, and then reopen it -- everything is fine.
-Ted
02-28-2007 05:51 PM - edited 02-28-2007 05:51 PM
(I copied it twice and scaled the top one for that "before&after" effect :))
Here's the 8.20 result:
Message Edited by altenbach on 02-28-2007 03:52 PM
Message Edited by altenbach on 02-28-2007 03:53 PM
