Scaling X axis
I would like to scale my x axis in order to control the number of millisecond represented per centimeter
i already calculated the maximum scale of my graph, the minimum of my scale it will be the cursor position and my multiplication scale is the sampling periods.
My question is how i supposed to do so that i can have each milliseconds correpond to 1 cm once i will print my graph .
Thank you
(3,035 Views)
Hi virtman,
Then you need to take the paper size into account. And the printer margins…
It's much easier to calculate once you know the width of the graph in number of pixels!
(3,026 Views)
the paper size would be chosen on the printer dialogue parameters lets say its  125 cm with 5 cm as printer margins
the width is 120 cm of the graph and i could have also the number of pixels by using a specified coefficient
But how  could i to have this result please !
(3,016 Views)
Hi virtman,
then you need to input those printer settings into your scaling VI to calculate with min/max of the X axis: x_min = x_max - 120cm * 1ms/1cm (with x_min/x_max in ms)…
(3,006 Views)
