Saving values with application
Greetings! I've made an application that receives temperature data. I have a control indicator that establishes the desired temperature. The problem is: during the .exe running, I cannot save a desirable temperature because If I reload the application it gives me the default value of the indicator (that I've defined). In conclusion: is there any way to 'store' the variables while the aplication is running? Thanks in advance
(2,894 Views)
Hi nasps
Yes, there are tons...
But you need to create a file that stores your settings.
For one setting, I would use the .ini file possibilities offered by labview. Their use is quite straightforward.
Please take some time to give a rating to my answer.
Cheers.
Doc-Doc
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(2,894 Views)
Hi Doc-Doc and thank you for your quick response! I've already heard about the .ini file, but I confess that I'm a little bit confused how to write/read in it. In simple terms: I need to save a value and when I re-start the application the saved value must be the default one! Can you help?
nasps
(2,894 Views)
Yes :
1 - open a text file. In it write :
[data]
default=100.00
save it as default.ini
Use the read and / or write capabilities as shown in the attached exemple.
Doc-Doc
(2,894 Views)
