10-12-2006 03:56 PM
10-13-2006 05:23 PM
m-s,
When you open up your subvi and then open up those instrument driver vi's do you see stars (*) by the name of the vi? It almost sounds like the instrument driver that you are using was compiled for a different version of LabVIEW and your program is compiling them for the current LabVIEW version when you open up your subvi. This would be the case if you have LabVIEW 7.1.1 and your instrument driver was written with LabVIEW 7.1. When you open up your subvi, it would recompile the instrument drivers for 7.1.1 and ask you to save them when you close your subvi.
Justin D
Application Engineer
