Saving multiple voltage read for single current
  I have a simple file that measures voltage for a current setting. I have an option to set it to read the voltage many time at the same current if I wish. What I;d like os for the program to save these values.
So say if I set the voltage readings to 5 my file will give me a current reading with 5 different voltages.
I've tried with shift registers etc but didn't have any luck.
Any insight would be appreciated.
Attached file for reference
Will.
(2,703 Views)
Anyone? Can't see that this would be hard.
(2,684 Views)
It would help if your program was actually readable. I'm sorry, but I can't tell what is going on in your program. You've violated just about every style guideline that there is. Do some cleanup of the wires, get rid of the nested sequence structures, use a subVI or two, maybe convert to a state machine, etc.
(2,679 Views)
