Saving measured data from three DAQ channels in a LVM file
I am acquiring voltage signal from three sensor using three different DAQ channels sampled at same rate. Now, I want to save the measurement data from three sensors in a file but I am not sure of how to do this.
Can someone suggest a suitable method to implement this.
Thanks.
(2,482 Views)
Write to Measurement File, Write to Spreadsheet File, etc. There are numerous examples. Explain the exact problem you are having.
(2,477 Views)
Look at the DAQ examples, continuous voltage to file which can do this for an ordinary data file.
LabVIEW ChampionLabVIEW Channel Wires
(2,462 Views)
