Saving data files for backward compatability.
I am currently saving the data in my appplication as a datalog file (LabView specific). The data contains strings, clusters, arrays etc.. so it's not a case if simple Binary data)
The problem I have is that the software/program is always being developed and more variable added to be saved. This software is kind of in use and I therfore need the old data files to be backward compatible with the new program.
With datalog files, you have to provide an image of the exact data file structure to load, so obviously with the new data structure, the old files will no longer load. How can I over come this? Is there a simple way.
The only way I thought of, was to save my data in.csv format. For example, I would save an exce
l/array matrix of say 20 x 100 which would give me 2000 cells to work with (plenty). I could then save all my data into this file, but always saving a 20x100 matrix, so even if I update the program in the future to save a further 5 data values/clusters etc.. for example, the saved matrix would not need to change and it would simply have the same image, but with 5 more cells filled.
Would this work?
I theory it sounds feasable, but do you have another/better method.
At present, I am using datalog file I/O and simply save a few extra blank clusters/doubles etc.. so I have a bit of scope to add thing, but this is not aceptable really.
There would also be other benfits for me if I use a .csv excel file, but it's not critical, other file formats will also be ok.
Thanks for any help/advice.
ADE
(2,865 Views)
ADE
It sounds like your question would be better answered in the general LabVIEW forum. This forum is for questions regarding the LabVIEW Datalogging and Supervisory Control Module, which is an add-on software package for LabVIEW. Your problem could be solved by using the DSC Module, but your question does not sound like you are thinking about using the DSC Module.
(2,865 Views)
