Saving current graph data
the problem with my using a chart is the ability to change my timebase...with a graph, it works better for me.
Message 31 of 41
(2,307 Views)
Can I increase my buffer size? Or program it to stop the freeze once the buffer is almost full?
Message 32 of 41
(2,285 Views)
I tried the Finite samples but it kept giving me errors.
Message 33 of 41
(2,282 Views)
It's helpful when you tell us what the error is. My guess is that you need to remove the Start and Stop DAQmx nodes. These are not needed with Finite.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 34 of 41
(2,268 Views)
That worked...Thank you sir!
Message 35 of 41
(2,262 Views)
No problem! Let us know if you need more help. There are also plenty of tutorials out there for stuff like this.
Thanks are best given in the form of Kudos. Smiley Wink
Cheers
Message 36 of 41
(2,248 Views)
I actually do have a question....about filtering. If I bought a USB scope online somewhere, (to analyze and record the signals like I'm doing in my vi) would it have a software filter? The reason why I'm asking is because when I get to 20-100mV ranges, I have a lot of variation in my signal, whereas a scope does not.
Message 37 of 41
(2,243 Views)
A lot of the time devices like that will have their own built-in filtering. The general rule-of-thumb when acquiring data is to oversample and average down to your desired actual sample rate. An example of a device that does this is any voltmeter ever.
Cheers
Message 38 of 41
(2,231 Views)
Do any of the fucntions in labview do this?
Message 39 of 41
(2,221 Views)
Should I just take a mean of the points and feed them to my graph?
Message 40 of 41
(2,207 Views)
