Saving an XY Graph in Excel using "Generate from Template.vi"
Hi everyone,
I'm working on saving an XY Graph to an Excel file and tried using the example from the help files: "Excel Report - Generate from Template.vi". However, I can't seem to connect the XY data to the template properly. I've attached an image of my attempt below, but it's not working as expected.
Does anyone have any ideas on how to make this work? Any tips or guidance would be much appreciated!
Thanks in advance.
(1,005 Views)
Accepted by topic author MarcusP.
I managed to resolve the issue. For a while, I had overlooked the fact that I was working with Excel, where I could simply leave the target cell blank. Once I realized this, I was able to resolve the problem by referencing the form, and I now display the array in that blank spot in Excel. From there, I reference that section in the graph, which worked perfectly
(946 Views)
