Saving a VI with a type def going into a concatenate terminal for 8.6 is unopenable in 8.6
If I try and save the below VI for LV8.6 I can't open the 8.6 VI in 8.6.
There's nothing special about the typedefed numeric. You can just take a normal numeric and "Make Type Def".
Workaround: Opening the 8.6 VI in 2012 and saving it again for 8.6 results in a VI that is now actually openable in 8.6.
CLED (2016)
(2,547 Views)
I am going to try and reproduce this behavior and see if this is a possible bug with LabVIEW 2012 trying to save version 8.6 VI. Way to figure out a workaround and everything! Is there any question in particular you are needing answered at all?
dK
(2,511 Views)
No. Just giving everyone a heads up.
CLED (2016)
(2,504 Views)
It is probably related to your concatenating tunnel which did not exist in LV 8.6.
What does that tunnel look like in your LV8.6 version of your VI?
(2,501 Views)
The block diagram doesn't open at all. I get this error:
CLED (2016)
(2,482 Views)
