Save xy plot to an image
(I have some xy data that I would like to create a 2D plot and then save it as an image (.jpg, .tiff, etc.).  I have seen in other threads that I could right click on a graph front panal object and then save as a simplified image.  Unfortunately I want to save many different xy plots and I would like to programically save each plot instead of having to do each one individually.  Thanks in advance for your help.
Kevin Baker
(3,092 Views)
You can use the method Get Image. Wire the image data to Write JPEG File. To get the method, just right click on the graph and select Create>Invoke Node. Then right click on this to select Get Image.
Message Edited by Dennis Knutson on 06-29-2006 09:38 AM
(3,087 Views)
