Save sample a specific time
Hello
I am quite new to LabView so i dont know much about it yet.
I am trying to make a VI that samples from a NI cRIO-9215 A/D converter, one channel for ECG and one for aterial pressure.
The VI is working fine just sampling and saving the data and i have made it with a timer and this also works fine.
Now i need to make a trend curve from the pressure samples in the last 30min. I want to make a 5-10sec long sample every 5min, and the totally lenght of the graph should be around 30mins.
This gives me 6 times the function should sample for 5-10sec from the pressure adc input.
The sample rate is about 200 and the max save time is 6 hours, maybe less.
I tried to make a for/while loop but this is just slowing the others functions of the VI way down 😞
I also need to make a VI that can view the saved samples. I was thinking that I can use the same trend function to generate a trend curve like the real time, from the logged data. But this isn't so urgent as saving the data.
I hope you understand my problem and are able to help me, and I apologise if this i a duplicate post!
Regards
Tommy
Message 1 of 1
(2,702 Views)
