Save project as
how can i do to rename a project that is already saved?
If i want save copies of my project during my day working i can not save the same project twice (with save as option) if it is saved first time. What is the right way to saving diferentes copies while i`m working?
(2,772 Views)
I think you should save different copies of the VIs that belong to the project, not the project itself.  This will give you convenient revision control, and all of the versions of the VI can be added to the project for easy access.
Chris
Chris Reyerson
Optical Systems Engineer
Arete Associates
Tucson, AZ
(2,752 Views)
