Save me from my rube
I want to total all data that happens on the same date. It's making me cringe that I haven't come up with another solution. May God have mercy on my soul.
Message 1 of 15
(4,583 Views)
Accepted by topic author GregFreeman
Nothing adds flair quite like a variant.
Message 2 of 15
(4,570 Views)
I don't have 2010 installed to try your snippet, but maybe you'd prefer to sort the original array first, something like this:
Message 3 of 15
(4,543 Views)
Another Potential Solution
Number of iterations = number of different dates
Greg Sussman
Sr Business Manager A/D/G BU
Message 4 of 15
(4,494 Views)
If you're using a database, I would suggest a simple GROUP BY and SUM combo in a query.
If not, and your main concern is aesthetics, OpenG is your friend:
It's probably not particularly efficient, and I haven't tested it, but it certainly is clean.
___________________
Try to take over the world!
Message 5 of 15
(4,477 Views)
Thanks for all the viable solutions! I appreciate it!
Message 6 of 15
(4,429 Views)
Darin, I really like the variant solution.  Very cool ... and quite a bit faster that the OpenG method.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 7 of 15
(4,419 Views)
I wanted to post this because I used Darin's method to go a bit more in depth. I wanted to group by multiple things such as "Category 1" Sub Category 1 -> Total
"Category 1" Sub Category 2 -> Total etc. So...here is my solution, let me know if it can be improved
Message 8 of 15
(4,380 Views)
@for(imstuck) wrote:
...let me know if it can be improved
Think of the Variant Attribute Name as a throw-away UID, and you can just start mashing together identifiers (using concatenate) rather than creating a hierarchy of variants of variants:
BTW - Cool solution, Darin! :thumbup1: And everyone vote for kegghead's Idea to make Variant Attribute atomic access cleaner syntactically (and faster?)!
Message 9 of 15
(4,360 Views)
To add an extra layer of protection against collision, when I concatenate strings to form an attribute tag I will add a separator (tab,pipe,etc.) that I do not expect to appear in the names themselves.  What comes in handy in many cases is my old friend Join Strings.vi.
Edit:  Was I the only one pleasantly surprised that the Variant To Data function happily dealt with an array of variants?  I can de-rubify some of my VIs now.
Message 10 of 15
(4,350 Views)
