Save light meter image screen
I'd like to save the light meter image screen in a jpeg or tiff file.
The exemple "Light Image metter" is great but i can't save the colored image screen of emission, when i save the output image, it's always in black and white.
It's possible to save this colored emission image ??
Thanks for your help
Aurélien
Message 1 of 8
(3,527 Views)
What light meter image and example are you talking about? Is this an image on an instrument display or is a LabVIEW indicator? If it's a LabVIEW control, you can use the method Get Image of a control and then use the Write JPEG File to save it. If it's the image on an instrument, then you need to check the manual for the instrument or contact the manufacturer.
Message 2 of 8
(3,511 Views)
Light meter image is a example of the Vision Labview Programme (:\Program Files\National..\Labview...\Exemlpe\Vision\Application\light meter)
The image that i d like to save is the image indicator (labview indicator)
I try the method Get image but, the output is a array of data not an image ?!?
Please help...
Message 3 of 8
(3,504 Views)
The output is an image data cluster that is wired directly to the Write JPEG image data input. You've also got IMAQ WriteFile that takes an image data type and saves it in an a number of formats. If you use this, you might have to specify a color table. I've only used the get image method and Write JPEG.
Message 4 of 8
(3,498 Views)
I'm sorry but i don't see what you mean...
May  be you can post a example, because i'm lost. When I right-click on my image indicator, i create a methode, then GetImage but the cluster is only a cluster of numeric (whitout image wire type)
Thanks again
Message 5 of 8
(3,490 Views)
Message 6 of 8
(3,488 Views)
Thanks, i didn't known this vi (write jpeg file.vi).
After some modifications i find a solution so, once again thanks !!
Message 7 of 8
(3,472 Views)
Thanks to you, I can post these beautiful Solar Cell emission images !!!
Thanks again
Message 8 of 8
(3,465 Views)
