Save data with Labview RT via FP 2000
I run 3 Vis with labview RT and acquire Datas each minute.I want to save this in a text file direct on the fieldpoint FP 2000 How can I do ?
I have tried to put via FTP adress a text file but labview can not open it or work with....
Chris
(2,789 Views)
Your attached VI cannot find its global variables. Otherwise, your VI appears to be fine. When you write data to c:\temp\txtvits2.txt, I recommend that you open the file once before the while loop and close it once after the while loop. Your technique of opening/writing/closing each time is inefficient.
I'm guessing your second comment about FTP is a completely different problem? After you put the text file via FTP, try the command "get -". This will dump the text to the screen (if there is any). It sounds like either your text file is not being "put" properly.
(2,789 Views)
The only problem was the character of the path which was c:\temp\txtvits2.txt.......In fact, it works with the same but like that : c:\TEMPTXTVITS2.TXT......
I've find the solution.....
Thanx for your help......
Chris
(2,789 Views)
