Save data upto completion
I cannot understand anything
 If you are not interested in old version i cannot tell anything
If can able to buy new versions, then no problem.
i think LabView 7.1 not that much old version.
after all I can do my work in this verion only.
if they are buy any new verion then only I can do with new verion
I cannot understand about open and run method
"Thanks with regards "
by
..........Gireesh..........
Message 21 of 24
(769 Views)
Can someone translate that for me?
Message 22 of 24
(763 Views)
All I got was that gireesh does not know anything about the available methods available and he does not think 7.1 is that old.
gireesh,
Open the LabVIEW help and search for either 'methods' or 'invoke node'. Also search for 'VI Server'. While you might not think 7.1 is that old, it is no longer supported by NI. I use 8.6 and 2009 and I cannot save back to 7.1 so I cannot provide code examples for you.
Message 23 of 24
(758 Views)
OK
I am a technical assistant only I have limitations. but I can tell to the higher authority that it is become an old version
we should go for the newer one.
I will try with the helps which you are given
by
Message 24 of 24
(744 Views)
