Save data to array(delete two previous wrong threads, please )
Sorry ,I have put two same threads in this board by wrong operation, please delete for me.Thanks.
Hi, I want to save a series of data to an array in the
following prosedure: The first data come (index of array
= 0), save the data to a(0), then the second data come,
array index +1,  save the data to a(1),...... I have write a
vi, but it doesn't work Smiley Sad
Message 1 of 15
(4,407 Views)
trinigh,
I'm not sure I get your point and only have LabVIEW 7.1, so could you just post an image of your diagram.
If what you want is to build (not save) an array, you should use the "build array" function in a loop, like this...
Epictetus
Antoine Chalons
Message 2 of 15
(4,404 Views)
Hi, TiTou. Here is the image of my vi.
Message 3 of 15
(4,408 Views)
Hi trinight,
here is the image of a VI that does it 'the labview way'  Smiley Wink  :
Try to avoid local variables. There is only very seldom a need for them.
-Franz
Message 4 of 15
(4,399 Views)
Yep, as I was assuming, what you are trying to do is to build an array (or add values in an array) to do this you have different possibilities.
As Franz mentioned, you can use a loop (while or for loop) with indexing, you can also use the "build array" function (like in the VI I posted) with a shit register, the principile is to initiate with a empty array before entering the loop and adding a value at end or at begining only when you want.
Hope my VI is clear enough and helps you, if not, feel free to ask questions 😉
Epictetus
Antoine Chalons
Message 5 of 15
(4,391 Views)
Hi, fahlers . I write a vi in the way of your image, but  only the first two elements change with the for loop. I don't know why. If the data source isn't from the for loop, there isn't the "enable indexing" how to the same thing?
Message 6 of 15
(4,384 Views)
Hi trinight,
I thought your problem was solved... I might not understand correctly what your are trying to do... could you post your last VI with some documentation in the diagram to explain what you expect your VI to do..
Epictetus
Antoine Chalons
Message 7 of 15
(4,377 Views)
In a WHILE loop, you can right click on the output tunnel and select 'enable indexing'.
(Likewise it is possible to right click a tunnel of a FOR loop to 'disable indexing'. It is just a different default for the two kinds of loop. )
Be aware that there may be a lot of memory allocation overhead when autoindexing from a WHILE loop: the compiler cannot know beforehand how often the WHILE loop runs and therefore has to allocate additional memory from time to time. In a FOR loop the compiler does know how many array elements there will be.
-Franz
Message 8 of 15
(4,370 Views)
Hi, TiTou. Thanks first. I was reading your vi, and made some change based on your vi, I wrote my purpose in the image posted.
Message 9 of 15
(4,369 Views)
This VI should work for You
Run it and let me know if it serves your purpose
Regards
Dev.
Message 10 of 15
(4,362 Views)
