01-22-2009 03:18 AM
01-22-2009 03:22 AM
Hi Annu,
i'm not sure what you mean, but to have a fixed array size of 200 values, you can use the initialize array funtion and overwrite the values with these from your file.
Hope it helps.
Mike
01-22-2009 07:36 PM
Hi Annu,
You can also use the for loop to limit the data reading .May be you can have alook at example attahced.You can get idea from the example.
Regards.
S.ahmad
01-22-2009 08:29 PM
01-22-2009 08:47 PM
Hi Annu,
I can only go down up to 8.0.Now I save it in version 8.0.If yuo cannot find 8.0 to open it then try to open LAbview example finder from help .Click on the help on Labview tool bar and select find example.When window pop up click search Tab and type XML.Then look for the VI name write to XML file.I attached the screen shoot of find example.
Regards.
Syed.
