Save as
Dear all,
I am doing a project which need to record some datas from a machine. I have set a Labview program to get data and make a Auto-save function.
the farmat of the datas are string. When the datas are prepared to save into the .txt / Excel file, the Labview called me to locate the saving address for the file.
I want to set a Automatic saving for the datas but I don't know the reason that why the program call me to set the save file location at each time.
The attachment is the program of the Auto-saving,
I have linked the address for it but it still called me to locate the address for the file.
Please help me solve this problem and teach me some method to program it.
Thank you
KIM
Message 1 of 11
(4,842 Views)
Try to wire the path diagram constant directly to the "open" function.
What LabVIEW version is this?
Message 2 of 11
(4,835 Views)
Thank you for your help first.
I am using Labview 7.1. is it any different?
Message 3 of 11
(4,830 Views)
hi,
check this vi...this may help you/give you idea
Message 4 of 11
(4,825 Views)
Kim has LabVIEW 7.1 and will not be able to open your 8.2 example.
Message 5 of 11
(4,821 Views)
sorry ..I am not able to convert ..I am having 8.2 only..
Message 6 of 11
(4,818 Views)
Thank you for you all help me to solve this problem.
I have change to "open" for the diagram but I still not worked.
Message 7 of 11
(4,810 Views)
Hi Kim,
and please:
Create real JPEG-pictures instead of just renaming a BMP file! Or (even better) use PNG for block diagrams!
(Yesterday I only received less than 20kb/s from NI, so your picture needs ~10s to load. Using PNG it will have a size of <10kB, allowing to load in <1s!)
Message Edited by GerdW on 01-17-2008 09:22 AM
Message 8 of 11
(4,801 Views)
Sorry!I will remember that!
Thank you!
Message 9 of 11
(4,793 Views)
You have to be a bit more specific. Can you attach your VI instead of a picture?
Have you also removed that other item (file dialog?)
Message 10 of 11
(4,771 Views)
