Save and load the front panel with Clusters
Sorry to sidetrack! I think this article does a good job of explaining the difference between strict and regular typedefs:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KnUSAU
Message 11 of 20
(2,608 Views)
I also like to use the MGI addons for such operations. There is even nice VIs for saving/loading settings into/from config files. Handy when you want to give the user the feature that your application "remembers" for example the Graph settings, etc...
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209753
Note that, you might find some little bugs, like once I had a problem with a VI living inside a subPanel: applying the settings back to this VI spawned some errors due to some prohibited operation in case of subpanel VIs. However it was quick to find the bug, and make a "subpanel compatible" variation of the MGI VI...
Message 12 of 20
(2,598 Views)
Hello Bob,
I was able to save the configuration of the "Input settings" only (maybe with different way) but my problem is to save the all front panel with several clusters.
Actually, I am able to save the configuration as explained but I am not able to load it into the all front panel, not a single cluster. 😞
Message 13 of 20
(2,581 Views)
Accepted by topic author yann31
Save time for yourself, and use the MGI toolkit, as I wrote in my previous post:
Message 14 of 20
(2,579 Views)
Hello GregoryJ,
Thank you for your help.
The code in your message was for "Save" or "Load" function? Also, what do you mean by "your code here"?
I put the VI example in my first message so if you could show me your idea by modifying it, it will be great.
My understanding is that your code is to save the front panel configuration right?
If yes, how to reuse the ini file to update the front panel according to the ini file.
Thank you in advance for your help.
Message 15 of 20
(2,578 Views)
Hello Blokk,
Thank you for the code. I reused as below and it seems to work well.
Message 16 of 20
(2,568 Views)
Small additonal question not in line with the current subject.
Is someone able to explain how to hide the "Stop button" and move to the right windows after cliking on the "execute button"?
Message 17 of 20
(2,565 Views)
File --> VI Properties, and you can customize any part, or just select the "Top-level application window" variation...
Message 18 of 20
(2,551 Views)
@yann31 wrote:
Hello GregoryJ,
Hello Yann31,
The two functions on the left read from the ini file (update your front panel). The functions on the right update your ini file (read from front panel). As an example, you could read at the beginning of your program and write the config at the end of the program, with your application code going in between ("your code here").
I purposely put a picture with all of the VI names showing so that you can easily recreate it yourself. Press Ctrl+Space to launch quick drop to easily find the VIs by name.
Message 19 of 20
(2,539 Views)
Hello Blokk,
Thank you for your answer, perfect.
Message 20 of 20
(2,528 Views)
