Save a file in a very particular path - help needed
Please look at the original post. The sub vi is included as well, there are two vi's.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 11 of 39
(1,103 Views)
yes, but it miss the 3th 🙂 check if directory exists 😄
Using LabVIEW 7.1
Message 12 of 39
(1,092 Views)
I don't know what 3th means but Check if File or Folder Exists is a VI that comes with LabVIEW.
Message 13 of 39
(1,087 Views)
i don't think it exists 😄 do you use openG library?
Using LabVIEW 7.1
Message 14 of 39
(1,079 Views)
I use OpenG on occasion. So?
You should be able to come up with something basic by using the low level File functions. You just can't depend on someone here giving you all the code you need. Though, you could try to use this to get a current version of LabVIEW.
Message 15 of 39
(1,071 Views)
Its not OpenG.
I am not sure whats available in 7.1. I hope you can build something like below as Dennis suggested.
Message 16 of 39
(1,057 Views)
There's really no need to check to see if the directory exists.  Just create it and handle the error that happens if it does already exist.
GCentral
Message 17 of 39
(1,047 Views)
in number to alphanumeric VI, why is build array necessary?
i put it in evidence in black box
PS: in theory the 31° day should be X, in your code it's different, maybe i don't have to consider J & K...in what way can i ignore them?
sorry but i find difficult understand in what way save file 😞 it's more simple for me make a strange program that make strange things that save files 🙂
then...after i build a path i have to check if it's exist,,,
@crossrulz: in what way could i handle errors?
Using LabVIEW 7.1
Message 18 of 39
(1,028 Views)
Please read the help file http://zone.ni.com/reference/en-XX/help/371361J-01/glang/byte_array_to_string/
I find it difficult to understand your last post. If you need to skip J & K you will need to handle that in the program, just use some comparison method.
Message 19 of 39
(1,019 Views)
i have made in this way...
i think that i have to put another "build path" to send the name of file i want to save.
but my problem is...error case is necessary? i have to save my file in everycase,,,
Using LabVIEW 7.1
Message 20 of 39
(1,014 Views)
