Save Word or Excel File in PDF format using Report Generation Toolkit and Activex
I am trying to generate a word file using Report Generation Toolkit. I also want it to convert it in PDF and save automatically to a particular location. I preferred the old NI forums to find a solution for this. I saw the use of Word Get Activex Reference. My problem is I am not able to find Activex Method for Word Activex. Are any other software changes required to get Activex Method???
-Devashri
(4,112 Views)
There is another PDF-related message in the Forum here that wants to read a PDF file using LabVIEW.  The solution was to use an external tool, pdfbox from apache.org, as LabVIEW has no native support for PDF documents.  You might check out this other related Forum request and see if it will work for you.
(4,059 Views)
Thanks for the reply.
Actually I want to convert word to pdf. At that time I am unable to get Activex methods of word get activex reference. Is there any other solution to convert word file to pdf?
-Devashri
(4,057 Views)
Word, itself, has the tools to convert its files to PDF.  Let Word do it.
(4,041 Views)
I got it.
I was facing problem because my MS word and Labview was not compatible to each other. Both should be 32-bit. Thanks for your valuable time.
(3,997 Views)
Attached file could help you to convert excel or word file to PDF.
(3,989 Views)
