Save Label by clicking
Hi all !
I'm trying to save labels of a clicked LED along with some data (please see the attached files).
Let say you click LED 1, 3, and 7. When you click  "OK"  the first time, a txt file  with the header Channel_1 should be created. When you click the second time, another txt file with the header Channel_3 should be created and finally when you click the third time, a third txt file with the headr Channel_7 should be created.
How can I implement that?
Thanks for your help.
Best regards
Kabanga
(2,784 Views)
First of all if you want to end up with three files. Each filename should be unique, so you should add a uniqueness factor to the filename. Second if an existing file should be overwritten you should keep the option "open / create".
André (CLA, CLED)
(2,773 Views)
Hi André,
each file should be unique.
How can I add this unique factor to the file name. Could you give me some idea?
Best regards
Kabanga
(2,766 Views)
Just create the name of the file programmatically and then use Build Path to create a full path. Your file path control would just be to indicate the directory where to save the file, rather than the full path to the file.
Message Edited by smercurio_fc on 05-02-2008 09:52 AM
(2,737 Views)
