Save Excel file without changing the template file
Hi
i need help with below simple Query
I am generating an excel file using an existing template. The new file gets generated but it is also making the changes in template. Is there a way using which i can avoid making any changes to the template file.
(1,115 Views)
Without actual code, it is hard to guide you. Are you using any toolkit or use the ActiveX?
Santhosh
Soliton Technologies
(1,093 Views)
Accepted by topic author RGrag
I'm assuming you are using the Report Generation Toolkit.
When you do a "Create Report", you essentially open Excel.  At this point, if you specify a Template Excel WorkSheet, the contents of that WorkSheet will appear on the "working copy" in Excel.  When you are ready to "Save Report to File", you need to specify the Path for the File.  To avoid overwriting the Template file, specify another file name.  That's all there is to it.
Finally, there is "Dispose Report".  This basically closes Excel, so once you've done this, Excel leaves memory.
(1,062 Views)
Yes, it works. I'm able to create new file without changing the template file.
(1,057 Views)
