Save Digital Data to a Text File
I can't create any new data, the test equipment had already been put away, however, I can send you the text file that I was saving, the digital to analog waveform, to give you an idea of what the data looks like. Hope this helps, I really appreciate it.
Tessa
Message 11 of 15
(1,455 Views)
What a shame. So looking at the file, its one signal per index of the digital waveform array?
Message 12 of 15
(1,446 Views)
Yes, that's the way I understand it.
Tessa
Message 13 of 15
(1,442 Views)
Ta Da! A bit long winded but you can do it.
David
Message 14 of 15
(1,437 Views)
This should work wonderfully, of course I won't know for sure until we run the test again but it looks promising. I just needed to alter your example to include a date/time stamp on the top for our records. After the change, the example wouldn't read the created file anymore but i don't need to read the file in labview anyways, it was good to varify that the data was converted correctly though.
Thanks a bunch,
Tessa
Message 15 of 15
(1,421 Views)
