Sate machines and DAQ
Before seeing this post thats what I did and it seems to work.  Is there any good tutorials on the website for using (when and where ) any of the vis from the DAQmx pallet?  I was using the help and some of the examples but there were so many links w the help I forgot my original question.  None of the daq mx examples were what I wanted.  When i set my timing daqmx vi to continuous how much data is collected and at what rate?? the full sample rate of the card and its read ( buffered) until I use the read.vi??  For proprietary reasons I can't post code so i'll try and explain.  I want to start reading an analog ch on a pxi 6230.  Do some stuff in a state machine all the while monitoring/collecting data on daq.  The purpose of reading is to make sure the ch I was reading didn't go above 100 mv at any time.  I have 6-8 state machines.  I thought I could continuously read the daq ch ( in parallel w the stuff I'm doing in the state machines) then analyze the data in my final ( END) state.
Message 11 of 11
(182 Views)
