Sampling rate
I have a amplifier which gives me a gain of 1000 and a low pass filter value of 53Hz. I am inputting this signal to NI-USB but the minimum sampling rate of it is 1000 Hertz. How can i decrease the sampling rate of NI Usb ?
Help guys I am very confused in sampling rate and how it works
Message 1 of 8
(3,709 Views)
Hi yum,
which hardware do you really use? NI-USB is certainly not the correct label...
Message 2 of 8
(3,704 Views)
Sorry i forgot to mention its NI USB 4431
Message 3 of 8
(3,700 Views)
You can sample at whatever rate you want. Generally you want to be sampling faster than your source, so just keep it at 1 kHz.
The sample rate is how fast the DAQ device records the input voltage. The low-pass rate is the fastest sine wave that will be transmitted through the amplifier. Though both are in Hz you can't directly compare the two.
If you sample a 53 Hz sine wave at 53 Hz you'll just see a row of constant points! If you want to see a nice smooth sine wave, sample at 10x or 100x the wave frequency. At 1000 Hz sample rate, you'll get 18 points per wave, which should be plenty.
Message 4 of 8
(3,685 Views)
And what about the number of samples ? If input analogue signal peaks at 53 Hz and the sampling rate of DAQ is 1k Hz then how much should be the number of samples ?
Message 5 of 8
(3,602 Views)
Hi Yum,
You define number of samples according to your requirements!
There is a simple formula describing the relationship: time * samplerate = NumOfSamples
(For continuous reading I advise to read 1/10 the samplerate, so at 1kS/s I would read 100 samples per iteration...)
Message 6 of 8
(3,600 Views)
What if the number of samples are greater than sampling rate ? How would it effect the measurement ?
Like for example if sampling rate is 1000 and number of samples are 2500
Message 7 of 8
(3,403 Views)
2500 Samples) / (1000 Samples/second) = 2.5 seconds
So it will take 2.5 seconds to take that data.
Message 8 of 8
(3,391 Views)
