Sampling Rate Question
I have been using an NI cDAQ-9188 with 2 NI 9324 modules to collect data. Using LabVIEW 2012 SignalExpress under DAQmx AcquireI I set the sampling rate to 250Hz and the samples to read to be 250.
When I output the logs to an ASCII file it says the dt=0.000605. With 250Hz I would be expecting 0.004. Any idea what the cause might be?
(3,628 Views)
Hi Jordan, I'm not familiar with SignalExpress, could you post some screenshots of what you are doing?
(3,604 Views)
Hi Jordan,
when in trouble you should read the manuals!
The samplerate given on page 6 fits to your 0.6ms dt value…
(3,596 Views)
As GerdW was getting at, the slowest rate that the 9324 can sample at is 1.65kS/s/CH.
(3,584 Views)
