03-26-2007 01:19 PM - edited 03-26-2007 01:19 PM
Message Edited by BHP on 03-26-2007 01:20 PM
03-26-2007 01:59 PM - edited 03-26-2007 01:59 PM
I got a sampe VI, but there are error message saying these sub-VIs are missing:
"IMAQ ImageToArray"
"IMAQ Init.vi"
"IMAQ Creat"
"IMAQ Sequence.vi"
How to get them?
Message Edited by BHP on 03-26-2007 02:00 PM
03-26-2007 02:33 PM
03-26-2007 02:57 PM
03-27-2007 10:00 AM
03-27-2007 07:08 PM
Hi, Mark:
Thanks for the reply. When I chose to browse according to "Directory Structure", there is an error message:"The NI ServiceLocator is not running. You will not be able to browse by Directory Structure."
Another thing is that I can not find the PCI-1408 device at the hardware part at"Example Finder" page, although I can find the device using the "measurement & automation expolore".
The attachment is the sample VI that I downloaded from internet. Is that possiable to get a self-contained package with the sample VI and the missing sub-VIs?
Best Regards,
BHP
03-28-2007
11:01 AM
- last edited on
07-01-2025
04:22 AM
by
Content Cleaner
Hello BHP,
When you receive the "NI Service Locator is not running" error it is typically because the service for some reason has been stopped or because a personal firewall is blocking the service from starting. The Knowledge Base below describes what you can do to fix the issue. Also another thing I would suggest is to go ahead and upgrade to the most current IMAQ driver. This way you can be certain that all the VIs are installed as well as the examples. The link below will take you to the download page for the "Vision Acquisition Software". This is just an installer that contains 3 drivers: NI IMAQ, NI IMAQdx (1394 cameras) and NI IMAQ I/O. The second two require a license or they will stop working after 30 days but the NI IMAQ driver does not need a license so you can leave these other drivers on your machine or choose not to install them. I hope this helps. Thanks and have a great day.
Error: NI Service Locator is Not Running
Vision Acquisition Software 8.2.2
Mark T
03-28-2007 01:26 PM
Hi, Mark:
Thanks a lot for your information.
It works quite good!
BHP
03-28-2007 03:01 PM
03-30-2007 10:07 AM
