Sample analog signal according to external trigger rate
Hi
I have a PCI MIO 16E4 DAQ card. I wonder I can use it to sample an analog signal at a rate determine by an external trigger. In my case, the trigger acts like a clock but does not necessary has a constant period. Would it conflict with the hardware clock of the card?
(2,650 Views)
Do you mean that everytime this external trigger comes in, the analog signal will be sampled in a finite acquisition fashion?
There is an example program here that demonstrates retriggerable finite acquisition which might be suitable for you. It uses the NI-DAQmx driver, so your PCI-MIO-16E-4 is supported by it. The trigger can be any TTL signal.
Victor
NI ASEAN
(2,634 Views)
