Sample VI DL3021A
I am looking for the LabVIEW driver for the Rigol DL3021A. If anyone has a sample VI that they could share, it would be greatly appreciated.
Steve
(623 Views)
There don't appear to be premade drivers for this.
However, it does appear to be a very standard SCPI + VISA device.  There's tons of general code out there using that.
I believe that you'll just have to make your own drivers.  A "sample VI" would just be any one of the dozens of VIs out there that send a *IDN? query and get a reply back.
(607 Views)
Hi Kyle,
I'm having trouble connecting to the device following your instructions and need some guidance on how to begin with the VI.
While I noticed it seems to be a standard SCPI + VISA device with a lot of general code available, I'm still unsure how to get started.
I understand that creating custom drivers might be necessary and that a sample VI could simply involve sending a \*IDN? query to get a response. Any initial steps or specific resources you could point me to would be greatly appreciated.
Thanks for your help!
Steve
(541 Views)
That device appears to support 3 different connections (USB, Ethernet, Serial RS-232).
If you're using Serial, you can start with one of the NI examples:
<LabVIEW 20xx folder in Program Files>\examples\Instrument IO\Serial\Continuous Serial Write and Read.vi
If you're using something else, then as long as you can get the instrument to show up as a VISA reference you can probably still use that same example except you delete the first half where it sets up things like the baud rate, flow control, and termination characters.
(533 Views)
I've encountered an issue with two driver VIs I found that are using USB and haven't been able to get them to work correctly.
Could you please offer some guidance or assistance?
(527 Views)
