Sample Integer and create array
Dear All,
I am looking to create an Array from a Integer value wich change continuously.
For example, I would like to sample(for ex: 10 times) this value every 100ms, and place each new sample in this array (and keeping all the samples values).
Regards.
(3,289 Views)
I would recommend putting the sampling inside of a while loop.
Also put a 'wait' inside the loop, attached to whatever time you want (ie 100ms for 10samples/sec)
Then wire the sample to "insert into array" whatever order you want (oldest to newest or visa versa).
Hope that helps,
Cory
Cory K
(3,287 Views)
How many samples do you want to store in the array at any one time.
I would recommend to initialise a fixed size array and rotate the array index +1 and replace the value at index 0. In that case LV doesn't need to call the memory manager all the time to increase your array.
Message Edited by andre.buurman@carya on 06-09-2008 06:26 PM
Message Edited by andre.buurman@carya on 06-09-2008 06:28 PM
André (CLA, CLED)
(3,283 Views)
Thank you Both for your ideas, The sampling is working very well.Smiley Wink
I just would like to know if it is possible to keep the first sampled data in the first Row, and add the new ones in the following rows.
"last n elements last"
For the moment, I do it like this :
The problem is I am obliged to wait until the loop stop, I would like to add the new values in the last row continuously.
Regards
(3,252 Views)
Your attachment went wrong.
You can attach a picture below the edit window, then post and copy the link location of the attached picture then select edit post and insert a picture with the copied link location.
André (CLA, CLED)
(3,242 Views)
Sorry Andre!
I hope, it's better now.
(3,237 Views)
