SXCI
I have try to connect the SXCI-1000 ,1127,1322 with the USB -4065 But both devices don't detect it other.
I try to add it using MAX but seem like the SXCI module is not detected.
Anyone have any suggestion or solution. DAQmx version 8.8. is installed .
(3,981 Views)
Hi leo,
  Seem  like you DAQms driver is ok since you are usinf 8.8 but what DAQ devcie are you using to connect with SCXI 1000.?
USB 4065 (DMM) cannot detect when you insert in usb port?Any device detected in window and ask you to install driver.?
For trouble shooting please browse to following link for SCXI and try it out .
SCXI Troubleshooting Resource
Configuring Your SCXI System with a DAQ Board
 http://www.ni.com/support/scxi/scxidaq/content.htm
Please try it out accoridng to to the preocdure provided in that tutorail linkand let me know again.
regards.
S.AHMAD
AE
(3,959 Views)
The SCXI-1000 is connected with SCXI-1357, SCXI-1127 and SCXI-1332. And then the SCXI module is connected to the USB 4065.
And the USB4065 is connected to the PC.
By using the MAX , the USB4065 is able to detect but the SCXI module is not able to detect.
I also read through the procedure manual that given by you but still not able to detect it.
Maybe cause by the USB4065 is not compatible with the SCXI module?
(3,943 Views)
Hi ,
I have sent the email to your direct email and Iopen the SR in my database.I receive your email in asean.support@ni.com.
Please email to me directly if you want to ask me about this issue.
Regards.
S.Ahmad
Application engineer
(3,920 Views)
