SVT - post processing data
Hi
I'm streaming data to a binary file which I would then like to open for analysis on another machine. The data is being collected from a microphone. Now here is the problem. If I scale the data to dB before saving, and then open the file, the values come out correct. Similarly, if I save the values as pressure levels, these values are also correct when I open them. If I wire the pressure levels (having first built a waveform) into one of the sound and vibration toolkit, sound level VI's then I get results out with a massive zero offset (in the negative range) and the 'amplitude' of the level is incorrect - e.g. -50dB to -5dB when the input is 94dB.
Any ideas what I am doing wrong? Basically I want to save the values as pressures, and then during post processing, convert them to dB.
Cheers
Dave
(2,558 Views)
Hi Dave,
As you know this thread is being answered here.
This message is for other customers experiancing similar problems, so they can find the answer.
Regards
JamesC
NIUK & Ireland
(2,544 Views)
