SVT Peak problems
Hi
I'm using the SVT peak vi to find the peak frequencies in a file which is between 10 and 30 seconds long. I want to pick out the distinct peaks. However, when I get the peaks out it gives me the exact peaks - e.g 997.12, 998.32, 999.23 etc when I would just like the key frequencies - e.g 1000, 3400 etc. Is there an easy way that I can set up the vi such that it only consider a peak to be a peak and ignore the +-hz either side?
Secondly, I am having trouble getting the output in a form I can use. The output I want is a simple array of frequencies vs magnitudes, but instead I get a 1d array of clusters.
Cheers
Dave
(2,855 Views)
Hi Dave,
Could you possibly post up the VI you are trying to use, as well as the data file you are working on? I can't find an SVT peak VI included with LabVIEW, is it part of a toolkit you're using, or a VI you've developed?
Have you tried using the Waveform Peak Detection VI which can be found in the Waveform Monitoring sub-palette (or by using the search option on the functions palette). This finds the locations, amplitudes and second derivatives of the peaks and valleys of a waveform.
Many thanks,
Mark
(2,840 Views)
