STRINGS AND FILE I/O
Good Morning Motivators,
                                        I was trying to write a VI  which involves representing numbers in coded format, but I have no idea. Please help me if you can.
This is the question:
Suppose we want to represent numbers in coded format. Consider the following code:
            1 = lv, 2 = ma, 3 = po, 4 = ni, 5 = be, 6 = ut, 7 = ke, 8 = su, 9 = lu, and 0 = ha
            For example, the number 987 is written in coded form as lusuke. Create a VI that takes a string as an input and outputs the equivalent number on a numeric indicator. Display the number -1 if the input code does not translate.
Message 1 of 17
(4,446 Views)
You will need Search/Split Sting to get 2 characters at a time.  From there, use a lookup table to convert your two characters into a number (hint: use Search 1D Array which will give you the index of the match or -1 if there was no match).
Give it a try.  We will not do your homework for you.  If you have specific questions, ask away.
Message 2 of 17
(4,422 Views)
Hello everyone!
Here is my solution. I need to work more in my discipline of programming.
If It works, It ain't stupid!
Regards!
Message 3 of 17
(4,403 Views)
General comment:
If you know how many times a loop will iterate, use a FOR loop.  In this case, you can use an autoindexing input tunnel to tell the loop how many times to iterate.  That would save you quite a bit of code in there (for FOR loop would just contain the Search 1D Array).
Message 4 of 17
(4,398 Views)
Define an enum that has your encodings, then use it to scan from string.dec.png
Message 5 of 17
(4,374 Views)
There was a discussion a while back where I remember where this can lead to false matches.  I can't remember why.
Bill
CLD
(Mid-Level minion.)
Message 6 of 17
(4,358 Views)
If there is not a match, you will still get a 0, so this will not meet the requirement of a -1 when there is an invalid code.
Message 7 of 17
(4,353 Views)
Message 8 of 17
(4,348 Views)
Who'd have known I'd be using this very code today?  😉
Bill
CLD
(Mid-Level minion.)
Message 9 of 17
(4,320 Views)
Hi Jimbe,
              I was looking at your snapshot and I had a quick question for you. How did you create the two tables ( One in pink and the other in blue)? Are they linked or something. I have trying to figure but no luck.
Thanks.
Vincent
Message 10 of 17
(4,293 Views)
