SSI USB
 Last week I stumbled across a posting that pointed towards a USB module that took SSI inputs. I can no longer find it! I think it was a fairly obscure product as it was only available in OEM version.
Does anybody know what it is!!?
Simon
Message 1 of 25
(17,187 Views)
Hello SSK,
I think, this module is the NI-USB-8451 I2C/SPI Interface. This module provide a SSI/I2C protocol.
information about SSI: link: What is Serial Synchronous Interface (SSI)?
Nick_CH
Message 2 of 25
(17,170 Views)
Thanks Nick,
I was looking for that for about an hour yesterday!!
Si
Message 3 of 25
(17,157 Views)
Can anybody tell me the difference between SSI and SPI?
Message 4 of 25
(17,153 Views)
Hello Scc,
The I2C protocole is a kind of SSI (Serial Synchronous Interface) where the data  uses only two bidirectional open-drain lines.
The SPI (Serial Peripheral Interface) is a synchronous serial data link standard that operates in full duplex.
More information about those protocole can be found on Wikipedia:
SPI Serial Peripheral Interface Bus
I2C Inter-Integrated Circuit
Best regards
Nick_CH
Message 5 of 25
(17,140 Views)
So could this USB module be used to read an SSI device?
si
Message 6 of 25
(17,133 Views)
Dear ssk,
Apologie, I just realize something, the SSI signal are differential voltage and the I2C are open-drain grounded.
That means you cannot directly connect them together.
The best think, I suggest you to study the sensor data (voltage level) and the I2C protocol (voltage level)
For example,
to connect the SCLK to Clock+ and Clock-, you can use a MAX 488 or similar
to connect the MISO to Data+  and Data- also.
Nick_CH
Message 7 of 25
(17,123 Views)
Not only can you not connect the two together, the 8541 driver does not support SSI.
You can find a definition for SSI here
SSI Bus {The Synchronous Serial Interface [SSI] bus consists of four signals; SCLK, SDATA, SDEN0, and SDEN1. SDATA is a bidirectional [three-state] data line which requires a pull-up or pull-down resistor. Data is sent in 8 bit bytes, LSB first. The SCLK signal is only active during transfers. Data is clocked out on the falling edge and clock in on the rising edge [of the Master]. The other two pins SDEN0 and SDEN1 are enable pins, active high.}
That means SSI uses only one data line , versus two for SPI. And they clock in on falling edge and clock out on rising edge. That is not supported with our 8451 driver.
Sincerely,
Chris G in AE
Message 8 of 25
(16,616 Views)
I thought I would post my solution for anybody else wanting to interrogate SSI using LabVIEW.
I used a PCI SSI card from www.deva.co.uk (product link http://www.deva.co.uk/product/deva001ssipci.htm) , the cards come with example LabVIEW drivers.
We have been using the card for some time with great success. They are 3 channel devices and we have a linear encoder on one channel and a rotary encoder on the other.
ssk
Message 9 of 25
(16,603 Views)
We want to use LabView with 6 SSI 13-bit absolute encoders. Basec on the info from the the past messages, we're checking the PCI SSI card  from www.deva.co.uk but we still have two questions:
In the website of the manufacturer, they say that provide LabView libraries to 5.0 LabView version. Are those libraries compatible with LabView 8.0?
As we want to use 6 encoders, we need to PCI SSI cards. Have somebody use simultaneously two of those cards with LabView?
Thank you in advance for any help.
LEMC
Message 10 of 25
(16,453 Views)
