SRS DS345 function Generator Example Code Issue
I am trying to get a Stanford Research Systems DS345 synthesized function generator to run using  the example code that came with the NI-driver. I've attached the example code below. The first time I ran the program I was given an error message #1074003951...ID Query Failed. The function generator is hooked up correctly and will communicate through Measurement and Automation Explorer without an error. When I troubleshooted this error further, it was recommended to try disabling the query. I set the query to false and it communicated with the instrument. Unfortunately, the program freezes after I hit run and there is no way to stop it (even abort won't work).
I have started using labview only 2 weeks ago and am very new to it's programming. Should this code have a while loop or is there something in there that is continuously running the instrument that I don't see? Do I need to add a stop button, if so, where?
Thanks in advance.
Nicole
(4,036 Views)
You have to first provide the driver you are using. It is not the one on NI's or Stanford Research's site. I would suggest you contact the vendor of the driver for help. The initialize function should be fixed.
(4,029 Views)
