SR830 Lockin-Amplifier - Difficulties to read buffer via VISA
Hello everybody,
I have a SR830 Lockin-Amplifier from Satnford. I would like to read the value with a GPIB interface with a computer
I am able to communicate with the instrument (commands such as *IDN? work without any problem). I tried the official Labview driver to download the data but it’s not working for me.
I have tried to use the SR830 Visa modified.vi from here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=202248
But in this case it’s also not working.
In fact my question is if someone has already a vi for this lock-in to get the display value and to visualize with labview and record a file with this value as a function of the time in a .txt format.
Thanks a lot
Laurent
(2,627 Views)
Hi Laurent:
    I'll have to dig into the deep recesses of my cranium for this.  If I remember, there was a bit of difficulty with the timing using single point samples.  We used the SNAP function instead, and it seemed to work a lot better.  At the time, there wasn't a ready-made Labview instrument driver, but there may be one now.  On the Lockin amp, be  SURE you have the GPIB assignments right....they start at 0, not 1, if I recall.
Let me know how it works.
eric
(2,599 Views)
