SR630 Read Errors
Good Morning,
I am using a VI to read (over GPIB) a thermocouple reader (SR630).  The issue I'm having is that, seemingly at random, the VI will read a value that "splits" the instrument's measured value into two lines, accompanied with an error.  (eg:  If the current temperature is 298.1, the VI will read 2, then read 98.1, then read as normal).
I have used the default measurement program provided in the instrument driver (ie, the 'reference' VI that shows how to take a simple measurement) and it has the same problem.  There doesn't appear to be any consistency to the error, either (ie, it doesn't always occur at the same time in a sequence of measurements).
Can anyone provide some insight into this problem?  I'd link my VI, but since the problem occurs with the reference VI I'm not sure that it's really a problem with my program.  I'm completely befuddled as to how I can troubleshoot this, given that it's ocurring on both the reference VI and my own.
Thanks very much for your time!
(2,745 Views)
Go into the initialize vi and write the VISA property "GPIB Settings.Unaddressing"=TRUE
Whoever wrote that driver did not read the manual closely.
"Should be" isn't "Is" -Jay
(2,731 Views)
Hi karosten,
It looks like this forum post might have the answer you're looking for : http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Timeout-error-when-using-SR630-over-GPIB-USB/...
I hope this helps!
Jonathan R.
(2,699 Views)
