SQL Server And LV5.1f1
I am experiencing problems accessing an SQL Server 7.0 database with LV 5.1f1
using SQL Toolkit 5.0.
Everything works fine when using Access to link to the tables in the SQL
Server DB, then accessing the linked tables from labVIEW. I can also access
the tables from Test Stand with no difficulties. The errors I see when trying
to access SQL Server directly from labVIW are as follows:
When using the Microsoft SQL Server Driver (3.70.06.23) I recieve the following
error: "[Microsoft][ODBC Driver Manager] Program type out of range". With
this driver, I can connect to the database, but cannot Perform a fetch on
it. When using the LV database browser, I can see the table in the db, but
can see neither the attributes nor the contents
of the tables.
When using the SQL Toolkit SQLServer Driver (1.12.00.00), I recieve the following
error: "[INTERSOLV][ODBC SQL Server Driver][SQL Server]Login failed for user
'*******'", where "*******" is my user name. I cannot find a
place in the Intersolve drivers setup that will allow me to enter a assword.
If there were a place to put a connection string, I could set the Integrated
Security = SSPI, and hopefully be allowed to login. But I can find no where
to enter such a string, even though an "Initialization String" field is mentioned
in the
intersolve "Advanced" set up tab help.
My preference is to use the Microsoft SQL Server Driver, since using intersolve
will involve additional licensing.
Do you know what is causing the "Program type out of range" error that I
am recieving?
Thank you for you help.
C Burgess
(2,916 Views)
I was having similar problems and I called Intersolve. They informed me
that I needed a server version of their intersolve database drivers.
($2,000 to $5,000). I solved the problem by using Microsoft access as a
front end database and SQL server as my backend database. This did correct
the problem. To do this open up Microsoft access (I used version in Office
2000) and create a new database file. I then added a database link to my
SQL server files. I then created a Microsoft ODBC link to this new
Microsoft access file. Presto... It worked.
Work Email: harmon-j@gouldis.com
Personal Email: harmonj@bright.net
Home LandLine: 330-848-0460
Work Land Line: 216-328-7113
"Chris Burgess" wrote in message
news:38df6477@newsgroups.ni.com...
5.1f1
access
trying
following
but
> can see neither the attributes nor the contents of the tables.
following
user
assword.
Integrated
where
mentioned
> in the
intersolve
> am recieving?
> C Burgess
(2,916 Views)
