SQL 'SELECT' statement
I use LV7.1.1 to read/update an Access Database, using DB Toolset.
When I use the Sql 'SELECT' query with LIKE operator, I do not get any results. (no error is returned).
The statement is:
SELECT Machine, System, AD, Query_Position, RefDesignator, Description
FROM AllLevel
WHERE ((Machine LIKE '*')  AND (System  LIKE '*')  AND (AD ='2000CV20012') AND (Query_Position ='AD') AND (RefDesignator='u1'))
It seems that the LIKE '*' is not translated well by the 'Microsoft Jet 4.0 OLE DB Provider'. I must mention that the statement works just fine under Access, not using LV.
Is there any alternative format for LIKE '*' that do the job?
Joseph Moshe
(3,217 Views)
Maybe Access has different syntax, but for T-SQL, the proper syntax for LIKE is to use the % character to match any string of zero or more characters and the _ character to match a single characer. In fact, the documentation says that while * and ? are understood,
"The % and _ (underscore) wildcard characters should be used only through the Jet OLE DB provider and ActiveX® Data Objects (ADO) code. They will be treated as literal characters if they are used though the Access SQL View user interface or Data Access Objects (DAO) code."
(3,210 Views)
Thank you! It solved the problem!
(3,204 Views)
