SQL Database Progressive Logging
I'm trying to use LabView's Database connectivity toolkit to store temperature and pressure data similar to the method in the example library (below)
Create, then LogCreate, then Log
What would be the best way to change this vi to log data progressively during a test as opposed to after the system finishes generating data?
(4,571 Views)
How often is "progressively"?
I generally avoid doing that.
(4,546 Views)
Ideally, about one data point every 0.25 sec
However, I'd be ok with bundling the data elsewhere and doing multiple data points at a time once per hour
(4,542 Views)
You don't want to be opening/closing a database every 250 msec.
(4,536 Views)
Ok, What is the best way to go from a data stream (Which will run for days+) to a database?
(4,527 Views)
Assuming SQL (I'm not experienced enough to know if this applies to other Database servers).  Use basic Insert statements (use string commands).
In this manner, you only need "DB Open Connection.vi", "DB Execute Query.vi", "DB free object.vi", and "db close connection.vi"
We will build an insert statement and wire it to the SQL query of the DB Execute Query.vi
Assuming a table with 2 names ("column A", "column B") named Test_Table.
"Insert Into Test_Table (column A, column B)
Values (1,2),(3,4)(5,6)"
Will insert the following.
Column A  ColumnB
1                  2
3                  4
5                  6
In this manner, a single connection and insert statement can insert multiple records.  Simply store your data for a predetermined # of records (shift register for example), then create and execute the insert statement.  Each row of data is contained within the parenthesis.  The comma delimited list can be extended as far as you want (be wary of timeouts however).
Adjust column names and the number of columns as you require.  I hope i attached the snippet properly.
(4,520 Views)
