SPI implementation on 7852R using Labview-RIO 12 Problem
I implemented SPI protocol and able to communicate with ADC (ADS8668), but the data i read from ADC are not proper, i get very unrelavent data from ADC for the proper inputs (reference to datasheet). I had gone through NI SPI implementation example and tried to implement in the same way with little chances.
Some of my doubts are, i have single timed loop running at 17 MHz, with that i set clock timing for SPI as 8.5 MHz, which is good enough to do IO operation with ADC (according to ADC datasheet).As datasheet says, Input/Output data can be given/collected at the falling edge of the SCLK, i set the program to sen/recive data exactly at the time SCLK signal falls, But i also a waiting time for clock state (for High and Low), should I send or collect data during the waiting time?
Please have a look at my VI and let me know if there is any mistakes.
PS :  ADC connections are very much proper.No issues to hardware connections.
Jay
Message 1 of 1
(2,913 Views)
