SPI example with SDW library - Cannot write to DIO of I/O card
I just tested the given example of the SPI library but I'm not able to write the digital waveform to my I/O board (NI6537).
I get always failure messages, no matter what I do. -.-
1) Buffer size. I do not know the size for my buffer, if I take 0 (indicating hardware buffering) it does not work....
2) Attempted writing digital data that is not supported.
      Data: 5
      Supported Values: 0, 1
Anybody could give me a hint why it does not work? Or what do I have to change in my VI?
Regards Chris
(2,692 Views)
Hi Chris,
I was able to reproduce your error and found the solution which i attached as screenshot.
The DAQmx write function input "data" necessarily has to be connected by a binary value which can be created by using the "Digital Waveform to binary" function block.
My VI works perfectly now, hope you can solve the issue too.
Regards chras
(2,656 Views)
