SOS:How to solve "internal fatal error:load.cpp line6345"?
   hello,everybody. now i meet with a sharp problem in labview. when i try to save a .vi file in labview, sometimes an error information will happen which is "internal fatal error:"load.cpp", line6345". i have tried almost every way to solve this problem but falied at last.
   Can you tell me how to solve this problem? thank u all!
(2,631 Views)
beryllan;
Let us know which version of LabVIEW you are using. After a quick search in here at the Discussion Forums, I found that problems with load.cpp were common in LabVIEW 6, (with special mentions to the Student Edition). If that's your case, try updating LabVIEW here.
Regards
Enrique
www.vartortech.com
(2,623 Views)
