SNMP OIDs help please
hello im new in snmp and im trying to find some usefull information for a router-switch that i have connecte
How many network interfaces does the main target host have?How many datagrams/packets (IP and ICMP) that have been received?
How many ping messages have been received by the target host?
Are there any network devices connected to this switch, if so give details of the network interfaces of the connected device?
How long has this SNMP agent been running?
How many datagrams have been sent by the target host Which ports of the host are currently active?
How many segments that have been received by the target host?
How many SNMP Get-Request PDUs have been accepted and processed by the 3COM switch Which ports are not available for traffic?
What is the CPU utilization of the router attached to the main target host?
if anyone can help me please 😉
(3,475 Views)
Since you have posted here, I assume this is a LabVIEW question, right? Are you using any toolkit?
(3,460 Views)
Y and only using putty to connect to it and i use snmp command to take the information but im not good with oids that i need to put to gain the right info
(3,447 Views)
Since you are not using LabVIEW, why are you posting here? Surely you can refine your Google search to find a better place to post your questions.
(3,435 Views)
