SMTP Error on compiled version
SMTP function: Error 1172: Error calling method system.net.mai.smtpcleient.send.
I got this error only on the compiled version. Not when i am running with the source code.
This error only occur on this particular machine. The other machine running same executable works fine.
I think there's some setting in windows that needs to be configure, but i dunno what.
Any inputs is very much appreciated.
(2,716 Views)
Do you have the correct version of dotNet installed. The error looks like it is trying to invoke a dotNet method and is encountering an error.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,706 Views)
I can check that, but if its not the correct version, error should be encountered also when running in source code.
(2,704 Views)
sorry been busy lately with other stuff...
any help on this?
Mark, how can i get the dotNet version?
(2,681 Views)
You can download the .Net framework here: http://msdn.microsoft.com/en-us/netframework/aa569263
There are also links on the side to previous versions of the .Net framework.
Matt M.
(2,672 Views)
